Will W. Posted February 10, 2017 Share Posted February 10, 2017 Good day, everyone. I finished this blade a little while ago. It's similar to the last knife I posted, but I wanted to challenge myself, so I did a three piece handle, and it definitely tested my patience and skill (while humbling both, I am still quite green.) It is flawed, but overall, I'm happy with how it turned out. The black sections are white walnut, and the red is oak. 3/16" pins for the oak and 1/8" for the walnut. The 1/8" pins, I learned, are quite tricky to peen, and they chipped a few times (not proud of them.) The blade itself is 5160, dual cycle tempered (after hardening of course) at 375° for ~an hour each cycle. 11" overall, and it has a slight recurve in it, which was intentional. It's hard, sharp, and fits in the hand well. The pictures are not fantastic, i apologize. Any thoughts, critiques, or recommendations are always welcome and much appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted February 10, 2017 Share Posted February 10, 2017 Anneal the pins before riveting, they will move more before cracking. I would probably have run the bevel farther up the side of the blade, but it is tough to tell just how wedgy it might be from the pics....you did a pretty good job on the polishing Quote Link to comment Share on other sites More sharing options...
Will W. Posted February 10, 2017 Author Share Posted February 10, 2017 BIGGUNDOCTOR: Thanks. I went down to 2000 grit sandpaper, so she is shiny haha. The bevel runs up to a little under half of the blade width. But i had not considered annealing them actually. Thanks for the tip, I'll try it in the future. Quote Link to comment Share on other sites More sharing options...
