February 13, 200818 yr Was looking for the blueprint titled Gramps Bender #BP0204 by Irnsrgn. I simply can't find it, and wanted to make one. Any ideas?
February 13, 200818 yr There seems to be a problem with the link to the blueprints from the forums page. I found it by going to the 'Home' page,>Blueprints>Blueprints 200 to 300> then go to the 4th page.
February 13, 200818 yr We are making some changes to the site and you found one of the changes in progress. The best way to find the blueprints is go to the opening page IForgeIron.com > search > type in your BP number. You can go to the top folders > blueprints > the blueprint series > the Blueprint series > then the specific blueprint. This is one reason I try to give directions when referring to a BP instead of just a hot link. If things fail, you can follow the road map and still get there. IforgeIron > Blueprints > BP0204 Grandpa's Bender, Modified
February 13, 200818 yr Holy cow. That is a pretty impressive tool. Thanks Jim for pointing that out. -Dan
February 14, 200818 yr Author Thanks Jayco & Glenn, I hit a stone wall while looking for this. Got it Now. Dan yes I saw this a couple months ago and thought It was something I needed. I make Muzzleloading rifles as a hobby and want to make as much of my furniture as possible. I think I can use this to bend trigger guards.
February 16, 200818 yr Benders like that, like hossfeld benders are very nice. If you're interested in one, right now harbor freight has on sale their hossfeld #1 imitation for 50$ which is far cheaper than I could build one myself (I picked one up)Harbor Freight Tools
