Hammer control question
13 hours ago, rockstar.esq said:
Another reason for choking up on the hammer is to reduce weird bounces when you're using the corner of the hammer face as a fuller.
Does it really work that way, I tought that the choking up in that situation was because you get more tilt with a shorter distance to the head. I really do not know, I prefer to hit straight and to use the edge or horn (Not london pattern) of the anvil or the pein.
gote,
It's possible to rotate the head to strike a corner while holding the end of the handle.  It's just less rotation of the handle than switching from flat face to a cross pein.  Landing the blow isn't the hard part, recovering from the wonky rebound is.
Yes absolutely if you mean the lateral "edge" of the hammer. I was thinking about using the far edge which seems to be advocated by some smiths.
