October 21, 20169 yr Picked up a Silver No.1 post drill that I'd like to clean up and hang on the wall of the shop. Works well and is mostly complete except for the auto feed arm/pawl. I know finding the part would be a miracle so I'd like to forge one as close to original as possible, problem is I can't find photos with enough detail to do this. Anyone here have this drill? I could use a few detailed photos and measurements of said arm and pawl. Here's a pic of my drill in its current state: Here is the part I need: I could figure out the length but do not know if there is an offset above and below the bolt or what the backside looks like. I know it's a longshot but any help would be appreciated.
October 22, 20169 yr Author After a bit more evaluation, it seems simpler than I originally thought. There is a cam on the gear, and an adjustable follower on the lower arm. Would still like the info but I'm going to mock something up and see what I can do.
October 23, 20169 yr I think I have a little bigger silver I will check and if I do I will get pics and make a pattern for you.
November 10, 20169 yr Author On November 8, 2016 at 6:53 PM, FlyingXS said: I have one I'll try to did it out today and post details. Thank You!
November 10, 20169 yr I have taken a bunch of photos with an imperial ruler,. We do metric over here. Give me an email address and I'll send them to you.
November 11, 20169 yr Author 23 hours ago, FlyingXS said: I have taken a bunch of photos with an imperial ruler,. We do metric over here. Give me an email address and I'll send them to you. PM sent. Thank you again!
