treytheknifeguy Posted August 1, 2016 Share Posted August 1, 2016 i was making a knife for a mate of mine and saw a drill bit in me scrap box and thought if i just use that it will be too brittle then the idea popped in my head if i run mig welds on the outside of the steel it could potentially keep it from being too brittle but keep its high edge retention so i tried it then forged it into a blade and it seems to work pretty well has anyone else tried this i was unable to find anything else on doing this Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 1, 2016 Share Posted August 1, 2016 I knew a fellow who used to forge using tig to heat the piece when he started... Most drill bits I use are HSS High Speed Steel and so very hard to heat treat properly and a pain to forge as well. Migging a softer steel envelope for it is just a modification of san mai. cf Quote Link to comment Share on other sites More sharing options...
Mark Ling Posted August 1, 2016 Share Posted August 1, 2016 58 minutes ago, ThomasPowers said: I knew a fellow who used to forge using tig to heat the piece when he started... Never heard that, very interesting. where there's a will, there's a way! Littleblacksmith Quote Link to comment Share on other sites More sharing options...
treytheknifeguy Posted August 2, 2016 Author Share Posted August 2, 2016 i used tig when i first started learning blacksmithing it worked but the torch would get too hot Quote Link to comment Share on other sites More sharing options...
