May 20, 201610 yr Can anyone identify the machine this fellow used to grind his blades? The accompanying article says he was a stock removal man. Looks like the machine is set up to grind two sides at once and presumably create a hollow grind. Is this something he fabricated or something he modified, or...? The article properhttps://clarksonhistory.wordpress.com/2013/05/06/secrets-of-the-dead-the-richtig-knife/
May 20, 201610 yr As I remember I once saw Jimmy Lile use a double belt grinder set up in that fashion though he was holding the blank in his hands IIRC. I think such grinders are usually custom jobs.
May 20, 201610 yr Thanks for posting that link. I found the article and the comments from people who had interacted with the man very interesting.
