Some final advice before welding...
Alright, so I live about 45 minutes away from my cousin's house where the forge will be located and I haven't had much opportunity to go and do any work on the tank I procured for making the forge, until today.  I have a plan on what to do but I just wanted some final thoughts before I go any further with the cutting and welding...
Apologies on the photo, I'm on a newer laptop and haven't gotten around to installing any decent photo editing software.
IMAG0061.thumb.jpg.0d3282dde01dcca8c12f2
Just so you have an idea of the work space setup, the forge will be physically outside, hence keeping the opening down to about 2 feet in width and a more pronounced hood.  However, the opening will be lined up with a 36" square hole in the wall of a 3 sided shed, basically a tin roofed ATV garage without doors.  We (anvil, me, vises, everything else) will be in the shed, but we'll be reaching through the 36" square opening to use the forge.  Air flow control and blower will be inside, pipe running from inside.
The tank stands a little over 5 feet tall, out of view on the base it has 4 feet.  The plan was to bend that cut piece in the picture a bit more so the sides are slightly steeper, cut the rear corners of it to fit the inner radius of the tank and weld it in flush at the rear, weld it for support near the front, then use brick/clay to level with the edges to close in the rear and front making the pot.  Tuyere would be in from the right where that white cap is, flue out the top, bob's your uncle.
Going solely on the limited description and horrible photo, will the pot/hearth design be ok in your opinion?  The diameter of the tank is about 28" at the inside.  The steel is 3/16" and I don't mind cutting and welding that piece to make a more permanently shaped pot but it doesn't need to be huge yet as to begin with we'll only be doing smaller things such as knives, tongs, hatchets, etc...  maaaaaybe a machete or two but that's a few months down the line.
I apologize for the novel, I get a bit long winded...  also the tank was used as a water tank on the back of a concrete mixer, that's what the white/gray is on the side.  Please, if you have any advice or criticism, feel free and thank you.
Bit late, but I see long stock as being an issue the way this is laid out at the moment. I'd extend the bottom cut towards the back more and then taper on an arc up to your "hood" so that you can lay full lengths side to side thru the middle of the fire if need be to work long stock.
  • 2 weeks later...
And you will want to work long stock even if you don't think so today.
Apologies if I'm not grasping the cut you're describing, but what do you mean as far as laying long stock side to side, do you mean multiple pieces of metal next to one another in the fire or laying a piece left to right so the entire piece is perpendicular to the front opening and in line with the air flow.  If I'm better served running the air flow from the back as opposed to from the sides then I can do that for sure.
It's not a problem running the air from the back to allow fuller use of that tray lengthwise, now that I look at it, it does seem a much better layout.
I haven't been able to proceed much at all since posting this due to other obligations, but I will be ramping it up in the next week or two and aim to be burning before next weekend.
You have a 20' piece of steel and you need to heat the middle of the piece---how do you get the middle into the hot spot of your forge?
That's why I asked about understanding the cut he's talking about.  I didn't know if he was saying keep the air from the side and put a hole out the back to allow the piece to be placed further in or just widen the opening so I could put things in sideways.
I will be back out there tomorrow to work on it all day after I attend a funeral, I will just have to think more about exactly what it is I'll be putting into the fire, really, and then modify from there.
I appreciate the replies though, gents.  Unfortunately I've never done this before so kind of flying blind.  Hopefully you'll excuse the noobishness.
  • 4 weeks later...
Just to give an idea of what I'm working with now, it's simple and literally the first fire I laid into it I was getting half inch up to a buttery yellow color and was able to draw out and do a decent fire rake, when I was eventually able to get a fire going.  It really was quite impressive and I really thought I'd gotten it right straight off the bat.  Just to give you an idea, the air inlet is 2" diameter.
Unfortunately, ever since then I've begun having issues keeping the coal burning, and starting to think it's due to lack of a firepot to keep the pocket of heat centralized.  The fire pictured is one instance where we were just chasing the heat for a solid hour, and I've been banging my head on the wall because I also feel the air coming from the side instead of bottom isn't helping or is just too much.
Should also I be breaking my bituminous coal down much smaller, say 1/2" pieces or less?  Using nut coal and breaking it down, but usually the majority of it is about 1"-1.5" pieces.  Using a hair dryer as the air flow, at even it's lowest setting would you consider that to be too much air flow?  Obviously a difficult question as not all dryers are standard speeds...  but I'm getting great air flow, just wondering if it's too much...
For sure, all criticism is welcome.  Fire away, it's a learning process, and thank you.
If you feel the need to localize the fire you can pile firebrick to wall it in.   Lighting the fire when it's been coked is a bit more trouble as is keeping it going.  Be sure to remove all the ask and clinker between runs (when it's cold so it's easy to sort.)   When you get a lot of trash built up in the fire it looks hot; but is taking heat not giving it!
