January 30, 201610 yr I have a problem with my #33 yang the wedge on the bottom sow block -- not the wedge holding the die though -- is always coming lose after maybe 5 min of hammering I have cleaned all the oil off reset wedge & still loosen up in two or 3 runs on the hammer ,This is a new thing for the Ph not sure what to do about it ??? or WHY its happening ??? only thing I can think of is heating wedge & resenting it in the sow block ? Or ruffing it up with a grinder some to help it stay in place better ? OR ??? any Ideas out there Please ! its getting to be quite a pain in the B-- *&%#@
January 30, 201610 yr You might try fitting the wedge with some prussian blue. You'd put on the blue, fit the wedge, take off the high spots where the die came off, re-apply die and repeat until you get a lot of contact area and very little blue left after you insert the key. Some shims would help fill in the gaps and that would work too. I found these instructions for fitting a key. http://www.littlegianthammer.com/resources/FitDieKey.pdf
January 31, 201610 yr Yes fit the wedge w/ Prussian blue till all the high spots are even. When you put the wedge back in put it in w/ a thin aluminum piece cut from a pop can, or a thin piece of copper. The easily formed piece will take up any spots missed w/ the Prussian blue and also it acts a little "sticky" also to hold the wedge better.
February 11, 201610 yr Dont rough it up with a grinder that will only cut down on your amount of bearing surface. As mentioned you need to have the majority of the key providing a bearing surface, yes to blue, or we even use a black permanent marker to colour in the surface of the key if we don't have any "bearing blue". I also vote for the shim of soft material, we use steel strapping strip to take up most of the slack, but we also include a strip of Aluminium, to deform and as said its a little sticky.
February 11, 201610 yr Author well tried a copper shim didn't help there's alot of oil in the wedge housing I can.t get to and clean out can't take the wedge out all the way cause it hits the hammer frame when I get a chance I will take the hole top unit off the hammer clean both wedges + slots will cut wedge leanth down or turn hole unit 180 degs so I can remove wedge when needed or ???? will try aluim shim also --- only other Idea I have is to lightly !!! file some groves or ruff up the wedge a bit *** what do you think of the file Idea ??? welded a lifting ring above hammer now & will lift hammer & put rubber pad on top of ply between hammer & base unit + also will put heavy mat under the hole thing should quite it down some to and been adding to the hanging tool rack just above hammer so its on going right now !! I will post a pic of it all SOON ! LOL Thanks for the in put keep it up Steve P
