Trying to find an anvil
A little searching on this site will give you a ton of ideas on what you can use for an anvil other then the common London pattern anvil to start out on untill you can find what you "want". don't waste time you could spend learning the trade in looking for the Common looking anvil. there are many things that could serve the purpose. This is actually a VERY common statement. think outside the box and eventually you will find a London pattern anvil if that's what you want.
Tate: If you put your general location in the header you might be surprised how many of the IFI gang live within visiting distance and I'll bet some have extra anvils or know where one is.
If you beat hot iron / steel on it it's an anvil. Period. The London pattern anvil is a pretty recent pattern and certainly not the only one around. some of the finest work in the world is done on a plain steel block.
