Forging Carver Posted January 19, 2016 Author Share Posted January 19, 2016 8 hours ago, DSW said: I have a great many cordless power tools that I use almost every day to make a living, but a cordless grinder isn't one of them. That said I have at least 8 4 1/2" grinders, 2 7" grinders and 2 die grinders. The only reason I don't have a 5-6" grinder yet is the easy availability of disks in my area. There's always at least 2 4 1/2" grinders and a 7" grinder on the work truck at any time along with a decent selection of wheels/disks. Oh yeah I know. I was only joking becuase that way I wouldn't cut through the the cord. With grinders, you could do like 3 cuts then need to recharge. You teach welding at the school I believe correct? Quote Link to comment Share on other sites More sharing options...
DSW Posted January 20, 2016 Share Posted January 20, 2016 Yes I'm a teaching assistant at the local votech school at night. Quote Link to comment Share on other sites More sharing options...
ausfire Posted February 3, 2016 Share Posted February 3, 2016 So how did you get on, FC? Did you fix it? I have a bunch of 4" angle grinders because they are relatively cheap and I hate changing cutting discs, grinding wheels, wire brushes, buffers whatever. If one stops running I go by the smell. An aroma of burnt plastic and sparks and white smoke and it's time to bin it and look for the next K-mart special. Quote Link to comment Share on other sites More sharing options...
Forging Carver Posted February 4, 2016 Author Share Posted February 4, 2016 19 hours ago, ausfire said: So how did you get on, FC? Did you fix it? I have a bunch of 4" angle grinders because they are relatively cheap and I hate changing cutting discs, grinding wheels, wire brushes, buffers whatever. If one stops running I go by the smell. An aroma of burnt plastic and sparks and white smoke and it's time to bin it and look for the next K-mart special. Oh thanks for asking. Well I just cut off the wire where I cut it and then re-wired the outlet plug into the cut end and finished off with some electrical tape. The cord is a little bit shorter now, but I always use an extension cord anyways. Quote Link to comment Share on other sites More sharing options...
