billyO Posted June 20, 2015 Share Posted June 20, 2015 (edited) Hello all, hope the end of spring finds everyone well.I imagine there are many variables that will effect the outcome, so here's what I did:Starting billet: 22 layers (alternating 6" long layers of .072 15N20 and .070 1095) clamped, handle welded on and one bead ran down the end of the billet. Forge welded, drew out, cut into 4 pieces, re-tacked and repeated 2 times to end up with 352(-) layers. BTW - all surfaces were ground clean before re-welding, and after the initial billet weld, I drew the tip out too much being the first time I've used my friend's 250# Chambersburg so had to lose 3" of material before the second weld. (Final billet size before final forge weld/drawing was approx. 5"x 1 1/2" x 2")Anyway, I ended up with a billet, 1 1/8" x 1/2" x 18". I cut off an inch of the tip polished and etched and the result wasn't what I expected, I took pictures and was going to ask what happened when I realized what I was seeing was most likely the 3 tack welds. I cut another 1/2" off and repeated the polishing/etching and am seeing the same strange pattern. I figured I should see pretty flat layers because all the work was done on the 5" x 7" flat dies, but there's a butterfly pattern.thanks I was planning on continuing to cut 1/4" slices off the end of the bar for another inch or so before cutting the grooves for a ladder pattern as per the original plan.Any ideas on how much of the tip I should plan on loosing due to the tack welds of the 4 pieces? Edited June 20, 2015 by billyO Quote Link to comment Share on other sites More sharing options...
LastRonin Posted June 22, 2015 Share Posted June 22, 2015 Sorry for piping in without an answer to your question, but dang! You should cut some thin slices of that and make pendants. It looks like jewelry to me. Beautiful pattern. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 22, 2015 Share Posted June 22, 2015 I was thinking the same thing. Beautiful pattern, nice contrast and a good scale to be worn.Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
