EricJergensen Posted December 22, 2014 Share Posted December 22, 2014 Well, not sure if it's a soup can or not. 6" diameter, 7" long. 2 layers of 1" Inswool. Kast-o-lite 2600 on top of the wool. Burner is 1/2" pipe nipple w/ .023 mig tip. I'm pretty sure it runs slightly rich. Burner is intentionally off center to encourage swirl. Pictures tell the story... Quote Link to comment Share on other sites More sharing options...
njanvilman Posted December 22, 2014 Share Posted December 22, 2014 Have you fired it up to temperature yet? If so, did it work as you hoped? The "hole" to put stock is a bit small for me. I guess if you just do blades or other straight stock, it will work. I bet the next one you build will be bigger. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 23, 2014 Share Posted December 23, 2014 It should work a treat Eric. Have you run it to full heat yet? Like Josh says it's pretty limited unless you're doing blades or other long narrow work. Teenylittlemetalguy uses his 2 brick forge more than his larger one, it's driven by a 1/2" burner and welds a treat, heck it'll melt your work if you're not careful. It's internal volume isn't much different than yours. How about a couple pics of it at max heat? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
EricJergensen Posted December 23, 2014 Author Share Posted December 23, 2014 I'll get some pics at heat next time we light it up. It's working really well for the purpose: mostly 3/16" to 1/4" round stock. Josh: It was specifically made to do small stuff while going really easy on the propane. Main forge is coal forge with a Diamondback 1-burner economy for taking on the road. You're probably right, tho. One project leads to another... Quote Link to comment Share on other sites More sharing options...
EricJergensen Posted January 5, 2015 Author Share Posted January 5, 2015 Here it is running full. Cell phone camera doesn't cope well... Quote Link to comment Share on other sites More sharing options...
