Mmm0513 Posted October 4, 2014 Share Posted October 4, 2014 Hey guys, first time almost getting the flat grind. But some things not right. It's curved like a frown shape instead of straight. Any ideas what I'm doing wrong? Matt Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted October 4, 2014 Share Posted October 4, 2014 Usually that will happen when you are putting more pressure at the handle (that's where you are holding it from). Like anything it will take practice to get the feel right so that doesn't happen. Quote Link to comment Share on other sites More sharing options...
TacticallySharp Posted October 4, 2014 Share Posted October 4, 2014 Put more pressure on the mid point of the blade and draw it straight to get the line straight. Use a push stick if you need it. Sway your hips instead of moving your arms. Quote Link to comment Share on other sites More sharing options...
Loneforge Posted October 4, 2014 Share Posted October 4, 2014 I scribe a center line on the blade edge and make even passes. When you grind toward the plunge line remember it is cutting on the way in and out.....you will be grinding more here every time. Try to get in and out quickly and go slower through the rest of blade. I also use a push stick. If you travel quicker to and from the plunge cuts you will get more even results and possibly eliminate that 2 inchitis! Hope this make sense to ya! Quote Link to comment Share on other sites More sharing options...
