September 5, 201411 yr I haven't seen it done with felt, but I like it!! It looks as if it gives some nice thick layers :) Not sure about "alternative to...". By definition, it IS home made micarta :) HMM can be made from any fabric, or textile and epoxy, acrylic resin, or other "thermosetting" plastic. I have even seen a former member here experiment with non-textile type stuff; seeds, even old coffee grounds :D Scott
September 6, 201411 yr I did a series of "working " knives handles from black dickies work pants layered with my old gray work uniform shirts.
September 11, 201411 yr I watched a guy on youtube who made what he calls "Crashcarta". He was using construction paper in lieu of felt. There was also some folks who put tooth picks or BB's on the top and bottom plates before clamping. Once everything was fully cured, a surface grind flattening it revealed a "damascus" pattern to the blank.
