Jacob Nothstine Posted July 16, 2014 Share Posted July 16, 2014 Have a Buffalo Forge #152 Post Drill with I think the original drill chuck. Picked up a Jacobs chuck at a garage sale and was going to install it on the drill press. The problem I'm having is getting the old drill chuck shaft out. I took out the set screw, now the shaft just spins freely, so I don't think its a morse taper or threaded almost feels like a bearing is around it. With the drill press being cast I don't want to hammer on it. How do you remove the shaft. Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted July 16, 2014 Share Posted July 16, 2014 Greetings Jac, Feed some WD in through the set screw hole than take a wood block put in on the chuck and give her a smack with your hammer Done it many times Forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
Eddie Mullins Posted July 16, 2014 Share Posted July 16, 2014 I thought you might be along to answer this one : ) . Quote Link to comment Share on other sites More sharing options...
