May 28, 201412 yr guys could someone help me design a box scraper blade to a blade scraper to apply it to a wheeled tractor from someone seventy horsepower means of these tools homemade? thanks for your attention
May 28, 201412 yr First trick is to relize you must be just wider than the tractor wheals. I can get pictures of the one i have (5' or 1.6m class 1 three point hitch) that i can use as an example second is to use where resiatant steels for the cutting edges. Old heavy truck spring can be used, as can the flange of old rail
May 29, 201412 yr Author thank you for your intervention and your precious words lighthouse treasure of your experiences
