jack j Posted March 9, 2014 Share Posted March 9, 2014 so i started to biuld my forge today and i have some pic for you to look at . let me know what you think. i will update when i get my fire pot and blower Quote Link to comment Share on other sites More sharing options...
EtownAndrew Posted March 10, 2014 Share Posted March 10, 2014 Looking good so far. Quote Link to comment Share on other sites More sharing options...
SoCal Dave Posted March 10, 2014 Share Posted March 10, 2014 This might go better in the "Forges" section. I understand you are welding it but most welders look at the other categories and will answer your questions there also. You might have more questions about your forge than about your welding. Good luck. Quote Link to comment Share on other sites More sharing options...
DSW Posted March 10, 2014 Share Posted March 10, 2014 Not bad. You may end up wanting to trim the sides down a bit so the stock can slide across the pot for longer lengths. This will depend on how high you set your pot. My sides are about 3", and my pot sits about 1" off the table. I may eventually end up building a bit of a ramp so the coal moves easier from the table to the pot vs the way I have it now. Here's the link to my build including the pot if it's of any help to you.. '?do=embed' frameborder='0' data-embedContent>> Quote Link to comment Share on other sites More sharing options...
EtownAndrew Posted March 11, 2014 Share Posted March 11, 2014 DSW mentioning the pot reminds me. I suggest that you do not weld the pot to the table after you cut out a hole for it. It will expand and contract with the heat and you will have welds pop if is solidly connect. The pot flange should just rest on the table top. (I welded mine and realized the mistake later.) Quote Link to comment Share on other sites More sharing options...
jack j Posted March 13, 2014 Author Share Posted March 13, 2014 thanks yes when i think about it now it should be in the forge section . im going to use a certer forge pot it is like 10" round with a hand blower .thanks for all the responces Quote Link to comment Share on other sites More sharing options...
