Ugly Rock Hammer
This was made from a 2 dollar hammer a broken 4 way lug wrench and ¼ inch square bar. The bottom end has a chisel for splitting rocks and can be used as a pry bar. The socket was cut above the start of the shaft. Then both sides of the hammer head was welded. The square bar was welded on and the shaft was ‘rough’ welded to aid in gripping the hammer. That. and, I am not so good at welding.
The spike was made long so that it can be used for digging and if it breaks there will be enough left to reshape it.
post-7305-0-32432100-1393766937_thumb.jp
post-7305-0-77672500-1393767017_thumb.jp
I certainly won't argue the "ugly" part! :-) :-)
