Crowned Anvil?
I have been looking into the peddinghaus anvil and the rep got back to me and mentioned that they are crowned from horn to horn by 3 to 5 mm. Is this good or bad?
The RIDGID Pedding-Haus Anvils?  I have a newer 125kg and it has no crown at all across the face.  Its obviously machined perfectly flat.
I think this might be their way of providing a tolerance over the length of the anvil from tip to tip - not across the width of the face. In either case, you are looking at about .080 to .200 as a maximum total height variation. As they state on the website, it's not a surface plate so this won't affect the functionality of a tool primarily intended for freehand forging.
In addition, a small amount of convex arc across the face width can actually be desirable as it provides some help in drawing.
Hmmmmmm, I've had three Peddinghaus anvils over the years.  The oldest was probalby 1960's vintage or so, it was marked "PFP".  None of them had a crown.  As HWooldridge said, it may be their way of stating a tolerance.
