January 12, 201412 yr Quick question, Will a forge fire burn through the bottom of my forge (side of a 55 gal drum)? thanks
January 12, 201412 yr type of fuel? how close is the fire to the bottom? the casing for my forges does not burn through easily because the fire starts 1" above the base and its bottom blast
January 13, 201412 yr Author side blast coal forge, inlet about 1 1/2" above the bottom. Should i get pre-mixed refractory cement?
