Frosty Posted February 15, 2014 Share Posted February 15, 2014 Neutral to a LITTLE rich. Dragon's breath that is a little orange is a little rich and good. If there is any yellow it's much too rich and making enough carbon monoxide to be very hazardous. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Broomhead Posted February 15, 2014 Author Share Posted February 15, 2014 Thanks for the clarification gentlemen. Not too worried about the CO right now, my forge and everything is in the open air for the time being. Quote Link to comment Share on other sites More sharing options...
Bill Mcclain Posted March 19, 2017 Share Posted March 19, 2017 Frosty wondering if you can shed some light on why I have so much trouble getting my burner started I have to shut the regulator down almost to zero and then slowly increase the PSI. back it off and then increase it again and then finally it takes off and does good I'm wondering if I've got a bad regulator Quote Link to comment Share on other sites More sharing options...
Frosty Posted March 20, 2017 Share Posted March 20, 2017 How are you lighting it Bill? Are you putting a bit of burning paper in the forge and slowly opening the 1/4 turn ball valve? You shouldn't need to mess with the regulator to light it up. Heck you can even open the tank valve slowly though I really REALLY prefer to see a propane rated, 1/4 turn ball valve in the circuit as a reliable FAST shut off in case of emergency. What kind of regulator are you using? A propane regulator RIGHT? If you salvaged an old acetylene reg the propane could have degraded any or all the rubber in it to the point of failure. I really need some details about what you have and how you're operating it to be much help. Pictures of the set up and burner help too. lit or unlit. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
