dickb Posted December 14, 2013 Share Posted December 14, 2013 I use an Otto Canedy Royal Western Chief Forge Blower.It has not been lubricated in over a year, maybe two.There is a brass air cock near the bottom and there is a small iron square bolt head near the letter Y in Royal.I think the small square bold head is a plug that was supposed to be used to add oil, but it's frozen and I don't want to use a lot of force and take chance breaking it. .Two questions :1 Can I open the air cock and add oil using a rubber bulb ear syringe or maybe a turkey baster.2 What kind of oil should I use.ThanksOops.I didn't look far enough, the question about what kind of lubrication has been asked and answered.The second question remains, about how to get fresh oil in. Quote Link to comment Share on other sites More sharing options...
John McPherson Posted December 14, 2013 Share Posted December 14, 2013 1. Tip the blower up. 2. Add automatic transmission fluid thru the petcock. Extra will not hurt because of #5. 3. Return blower to original position. 4. Turn the handle for a hundred or so slow rotations. 5. Drain the now filthy excess lube thru the petcock. Repeat as necessary. And, oh, yeah, on old machines it doesn't hurt once a decade or so completely disassemble every bolt and screw and put some Neverseize on the threads during assembly so that it comes apart next time you need it to. Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted December 14, 2013 Share Posted December 14, 2013 Greetings Dick, Just an addition to Johns suggestion... The plug is a small pipe thread with a 1/4 square drive.. The correct socket should remove it with ease... Tapered threads and all... Forge on and make beautiful things. Jim Quote Link to comment Share on other sites More sharing options...
