My rose
I've made a few of these when I have down time at work I built this one for a friend during my breaks. Just wanted your opinions. Everything is cut from .125 a-36 plate and the stem is .375 rod. I used a torch to heat the pieces and hammered the shape of the vise one at a time welding them together with L-56 hard wire. Bead blasted everything and then buffed and reheated to get the color. The engraving was done with a diamond bit and die grinder. The gold detailing was done with brass rod then clear coated.
post-46431-0-64957800-1381630377_thumb.j
post-46431-0-12071400-1381630396_thumb.j
post-46431-0-38312700-1381630408_thumb.j
post-46431-0-65843200-1381630526_thumb.j
  • 3 weeks later...
