2Tim215 Posted September 20, 2013 Share Posted September 20, 2013 Hi all Was hoping someone would know the hammer (and person) in below pic. I am planning to build another hammer in the next few months and am perticularly interested in his use of a shock absorber instead of the normal spring arrangement usually used. My first was based on the little giant and I don't like it so am either going for the leaf spring or something else. Any info on how this hammer worked etc would be appreciated Thanks Tim Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 20, 2013 Share Posted September 20, 2013 The home built hammers using shock absorbers that I have knowledge of were not considered as good as other linkages; the absorber absorbing quite a bit of power from the system. You might ask Jock over at anvilfire.com about his experiences with the one he built. Quote Link to comment Share on other sites More sharing options...
Geoff Keyes Posted September 20, 2013 Share Posted September 20, 2013 I built a #50 hammer after the first JYH 's were built. We used a spring package from a truck, re-bent to keep the width down. The shock absorber hammers were an early try. The shocks were too slow to respond and they stole energy from the system. I used a Champion as a model and came up with this. With very few mods it's been in operation since 2000 One thing you might consider is a tire drive version of a Rusty. Geoff Quote Link to comment Share on other sites More sharing options...
macbruce Posted September 21, 2013 Share Posted September 21, 2013 I think it could be done with a passive air cylinder better than a shock absorber....But the R&D could get oppressive and expensive. Hackney hammers worked very well. I've only seen one mechanical/air hammer operate and I was impressed. Quote Link to comment Share on other sites More sharing options...
2Tim215 Posted September 21, 2013 Author Share Posted September 21, 2013 Thanks Thomas, thought that would be the case. Thanks Geoff - what you have there is what I have in mind but with a tire at the bottom driving a pully system. Tried the pully drive on its own and found a tire driven system far more responsive. Thanks macbruce, what I originally had in mind for the hammer was a truck coil spring in a cylinder with a 50mm centering shaft - would work like a shock without losing any energy. Might just give it a go just to see if it would work. Quote Link to comment Share on other sites More sharing options...
