September 10, 201312 yr besides, if it's not company property, they have no say on if you take it home. and if he comes back to get it, it got tossed out. It's not the company's job to store his stuff.
September 11, 201312 yr Author This is the blower. My plant manager said to take it home, it was taking up space. Apparently, the guy had brought it up here to "fix" it but hadnt gotten around to it. I hooked it up, and it didnt come on. I rested my hand on it, and could feel the motor trying to pull. A couple squirts of WD-40 to where I thought the bearings should be, and it was blowing like a champ. however, it got weaker after I unplugged it, moved it to where my forge was, and plugged it back in. I may have to take it apart and grease the bearings. Also, I kind of jumped the gun and bought some corn to burn. I set my weakened blower in front of my tuyere and turned it on. i was getting a pretty good draft through my air hole. I built a good bed of pallet wood coals in the bottom of the forge and added the corn to it. the corn did nothing but smolder and clump together. Am I doing something wrong? Need alot of airflow? Need to get the pallet wood coal bed hotter? what is the best way to get a corn fire started? Or is this just some kind of blacksmith joke? lol
September 11, 201312 yr is the blower just placed in front of the hole of the Tuyere? or did you reduce the outlet on the blower to fit the hole? If it's just open you're loosing A LOT of air and if the blower was weak you're not getting much air into the tubing at all. The bends and length all add to drag on the air, as does the reduction in size from blower to pipe. If you reduce it to force all the air into the pipe you may get more airflow. As for using corn, I can't help you. I've got decent access to blacksmithing coal so that's what I use.
September 11, 201312 yr Author I just had it sitting in front of it. I figured it would be enough to just get the corn burning,just to see if it would, in fact, work. I'll have to go ahead and work on my tuyere some more, then. Like I said, I jumped the gun because I was excited lol. The coal bed was hot enough to get a piece of 3/16 round brass cherry red, though. (Small victory) :)
September 11, 201312 yr As Molinar ( I know I misspelled it, but I believe that's the name of Thor's hammer) suggests, build a duct to adap your blower to the tyre. Might meet an air gate to controls the air. As I understand it, corn will clump as it converts to charcoal, something like coal coking. The smoking, burning corn isn't your fuel, it's being made in to fuel, it's the clean burning coals you want as fuel. So like a coal fire you "coke" the corn, keeping the coals in the middle and bank fresh corn around the fire ball to insulate it and to provide converted fuel. Might need a watering can to keep it to a reasonable size. Sight search burning corn on IFI, I know it's been discussed
September 11, 201312 yr Author Mjolnir is the spelling. (m is silent). aah ok, so the black clumps left over this morning probably still contain energy... Ill have to try again once i get my air supply in better operation.
September 11, 201312 yr Didn't know about the silent m, happen to know the name to the rams that pulled his chariot?
September 11, 201312 yr Author Tanngrisnir (Old Norse "teeth-barer, snarler"), andTanngnjóstr (Old Norse "teeth grinder") google search is wonderful lol. just not for corn forging...grr.
September 11, 201312 yr Lol, you are now officialy on lindas $@!& list. So your looking at a 5' deap fire pot? Big pot, it will be fuel hungry but it will heat big iron. Can you rope the wife and kids into swinging a sledge?! Sight search IFI. There was a descusion on corn heard some where. If you can't find it as again, Some of the old guard has some good Google foo.
September 11, 201312 yr Hey, when you build your flue, I've seen old forges that deverted air up the flue to impove draft with smaller flues. So since you have two blowers... Migt be nice to revert some to you in the sommer too!
September 11, 201312 yr Mjolnir, pronounced Myol-n(ee)r. So, no, the M is not silent. think Mule-Near, but spoken like boomhour from King of the hill. there was actually a very recent conversation about using corn.
September 12, 201312 yr Author Thor-thanks for linking that thread. I've done searches and haven't come up with that thread yet. It was a success! When I get time at work tomorrow I will post pics and specific fire actions. I had trouble controlling the fire and burned through A LOT of fuel. Probably just because of my fire management skills, but whatever. I'll improve. Like I said, MORE INFO TOMORROW! goodnight, guys. And... would you fellas rather I started a new thread for corn? Or no? Later.
September 12, 201312 yr Five threads down from where this is posted there is a thread on corn forge,,,really did not seem that hard for me to find!
September 12, 201312 yr Author It doesnt really explain how to get the fire started and keep it lit. this was a big problem of mine- people just say "it cokes up like coal". I have no experience with coal, so i didnt know that you have to burn that part of it, not the kernels. But, with some experimenting, i was able to get it going. will be posting a (sort of) in depth recount shortly.
September 12, 201312 yr You'll get it figured out. I still get to messing around and have the coal fire go out. A square chunk of 2x4 stuck in your coal fire when you are letting it idle for a bit will povent that. Can't sleek to corn, as to charcoal, in the same situation it just burns up the fuel when your not looking.
September 12, 201312 yr Don't mind Rich, the Crumudgeon part fits, though I think he's more a a journeyman than apprentice at this point. starting a new thread is the way to go, because really it's a different subject.
September 12, 201312 yr Rich tends to candy coat things more than Tommas or Steve, but yes he definantly has a finess uncommon to the breed.
