fishing guru Posted September 1, 2013 Share Posted September 1, 2013 Would E2 grade tool steel work good for making knifes. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted September 1, 2013 Share Posted September 1, 2013 maybe usable, I cant say if it woud be good. It does get to HrC of 60, If you can move it at heat, also how will you heat treat it ? and Where did you find it ??? C 1.2% Si 1.0% Mn 12% Mo 2% not sure what that 95% W and 5% Cobolt means, as if that was the alloy its not steel. and Yes I saw that note in the listing I got also Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted September 1, 2013 Share Posted September 1, 2013 Never heard of e-2, I found that same chart and really don't have a clue if it's right. The chem analisis Curmudgeon list indicates that it is an air hardening steel. Cobalt and Tungsten would make it like a high speed. Heat up a piece and test it. If it air hardens and is some kind of high speed steel I wouldn't mess with it, but it may make a decent small knife. Quote Link to comment Share on other sites More sharing options...
fishing guru Posted September 1, 2013 Author Share Posted September 1, 2013 My buddy is a mechanist and he recommended it for making knifes.it is used to make punches and dyes. Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted September 2, 2013 Share Posted September 2, 2013 Are you sure it's not A-2? That's a real tool steel and makes very good knives. It is however an air hardening steel and to get the most out of it you'll need to send it to a heat treater. Quote Link to comment Share on other sites More sharing options...
