Half way finished
So I started this last night and I think I may need to make drift that would best open the hole properly. But other than that I've learned a few new techniques and have found this one a little "easier"
I started the blade first like a rookie and had a friend helping hold tools so my eye didn't stay straight either. I was curious about a bickerns horn and if maybe that would help the process at all.
Also, I tried forge welding a piece of flattened rebar. Got it on my second try. Not all the surface area but enough that I tried putting a chisel into the seem and the edges folded rather than splitting so I guess it worked. I'm gonna try a few more times with a longer seam until I'm better
Excited to hear what you think
post-41829-0-39120300-1370733179_thumb.j
post-41829-0-73881400-1370733309_thumb.j
post-41829-0-73665700-1370733321_thumb.j
post-41829-0-60119700-1370733420_thumb.j
post-41829-0-69421400-1370733436_thumb.j
Hey not bad at all. You have the profile looking quite nice. What did you use to open the eye? It's look very angular. Or did you wrap weld it?
I used a cutter to make a slit.... And I home made hit chisel for part off it then a railroad spike for some more then finally the biggest chisel I have. Definetly angular. I've just come into some spring steel I've heard make good tools. I may just but some fresh stuff though from a local dealer and make a proper drift and other things. Getting started is always the hardest. :)
Yeah I have a source of maple scrap here that ill probably use. Few long ones could constitute a pretty large axe head !:)
  • 2 weeks later...
So I decided the eye was too misshaped and thin. I got cut it open and will do my best to weld a new one on.
