July 28, 200718 yr Hi all. I am putting together a one-brick forge so I can make a couple of one off woodworking blades that I need. My understanding is that the regular bernzomatic plumber's style propane torches will not work. Would the mapp gas torch like the below one work? On 3/8" O1?Trigger Start Torch Kit (I have a regular coal forge too. This is just to prove a point to someone.)
July 28, 200718 yr Hi all. I am putting together a one-brick forge so I can make a couple of one off woodworking blades that I need. My understanding is that the regular bernzomatic plumber's style propane torches will not work. Would the mapp gas torch like the below one work? On 3/8" O1?Trigger Start Torch Kit (I have a regular coal forge too. This is just to prove a point to someone.) I guess it depends on how hot you want it. A bernzomatic should get you into the low yellow anyway if you use light brick, maybe a bit more if you use a kiln brick. More heat easier with mapp though of course. Frosty
July 29, 200718 yr Make sure you keep the tip of the burner OUTSIDE of the brick or you will melt it off. Don't ask how I know this.
