July 17, 200719 yr Anyone have any suggestions for which gauges of copper sheet work well for someone that's teaching himself repousse? I'm having a ball with copper flashing, but would like to try for something thicker. -Jim
July 20, 200718 yr Depends on the overall size of workpiece, and height for pattern/design you want to raise, Old copper water cylinder tanks can be used or up to 0.125" for something like a weathervane body, Just keep it well annealed and keep re annealing as necessary as you are working the material it will work harden You could even use copper foil and a ball pointed tool to inscribe patterns for jewellery etc, Give each a try, there are no hard and fast rules but don't forget enjoy yourself while you are doing it.
July 23, 200718 yr From everything I've read and with the "little bit" of experience I have on the subject, 32 ounce or 18 gauge (.043) copper is good size for doing repousse (and raising also). Walker
