Razzputin Posted March 10, 2013 Share Posted March 10, 2013 Well on Friday I said to myself that I will finish the two pairs of tongs I started and voila! I have done it. The first pair are as ugly as sin but are surprisingly very useful. The second pair are by far much better and look great as well. Here are some pics of them as well as some of my other tools I have amassed. These are all my forge tools I have so far. From right: 1kg machinists hammer, 1 water scoop, 1 punch, 1 cutter, 1 First pair of tongs, top - Second pair of tongs, Bottom - Fire poker. Detail of the scroll work on the end of the poker. The water scoop. My first pair of tongs made from 10mm steel bar, head and neck forged, handles drawn out near head and widening to the back, this balances them very well. The two parts were riveted together by myself. Detail of the head. As you can see the one lip is longer than the other, this makes it an excelent tool to use when doing rivet work as the longer head can be placed over the rivet and is used to hold it in place while you shape the other side of the rivet.I have not included a picture but the lips have a groove down the center so as to be able to grip onto the piece being worked on. My pride and joy at this moment. The second pair of tongs I have made. The heads were forged from 16mm bar and then the neck was drawn out to only 1cm, I then cut them off of the original stock riveted them together and then welded the handles on afterwards. Size comparison. This one also has the groove in the center so as to be able to grip better. Detail of the head. Here you can also see the top lip is slightly longer, this is so that I can scoop the piece I am trying to grab rather than chase it around the fire pot. You can see the welds that I made as well. Thank you all for reading my posts I appreciate it very much. Fell free to drop any comments I look forward to them. Quote Link to comment Share on other sites More sharing options...
Ridgewayforge Posted March 12, 2013 Share Posted March 12, 2013 That all looks good! Try and make your next set of tongs more like the Brian Brazeal method-shorter boss area-it works really well. Keep up the good work, it all looks swell! Quote Link to comment Share on other sites More sharing options...
Razzputin Posted March 13, 2013 Author Share Posted March 13, 2013 I will do so thank you for the advice. Quote Link to comment Share on other sites More sharing options...
