Rhettbarnhart Posted January 3, 2013 Share Posted January 3, 2013 I got post vise for christmas and would like to know what it is/show it off on the vise's font jaw it says new london conn (i think this stands for connecticut) NO. 40 if yall can give me any info on this vise it would be great thanks,rhett Quote Link to comment Share on other sites More sharing options...
Loneforge Posted January 5, 2013 Share Posted January 5, 2013 Score! Quote Link to comment Share on other sites More sharing options...
MLMartin Posted February 15, 2013 Share Posted February 15, 2013 Certainly not the original screw & box. You might be able to fix it up a little more and cover the screw some so it does not get to gritty. Also the jaws look a little bent. Do they close straight? If not I can help you fix it some. Quote Link to comment Share on other sites More sharing options...
Rhettbarnhart Posted February 15, 2013 Author Share Posted February 15, 2013 what makes u think the screw and box are nonoriginal?the screw box is an oval shape that fits into a similar oval shape in the vise body so it wont turn.the jaws close parallel but have a section ground out,i will bring it to ur place and let you look it over Quote Link to comment Share on other sites More sharing options...
C.D. Mitchell Posted February 15, 2013 Share Posted February 15, 2013 Looks like a serviceable vise to me. No need to get picky about having the original screw, box, spring, mount etc. If it loosens, tightens, and holds whatever you want to hold, then you have everything you need in a vise, enjoy it! Quote Link to comment Share on other sites More sharing options...
MLMartin Posted February 15, 2013 Share Posted February 15, 2013 The screw looks perfectly usable, just not original. The first reason I would say its not original is because it looks spot on to be a house jack screw. Secondly the screw is much longer than the vise can realistically open. The screw has a unneeded chunk off the front. The general shape of the vice more than likely makes it English. Out of the many English vices, and pretty much any other nations vices none of them used an exposed screw. With an exposed screw you run a much greater risk of the screw being struck with a hammer or damaged during shop use. Also an exposed screw will collect lots of grit and scale from normal use. Scale and grit will quickly ware out a box because it is much harder than the screw and box. Quote Link to comment Share on other sites More sharing options...
