Azur Jahić Posted October 21, 2012 Share Posted October 21, 2012 ok my breast drill have to speed wich i use it i use only one speed i put crank on secont shaft but what is purpose of first axle Quote Link to comment Share on other sites More sharing options...
John B Posted October 21, 2012 Share Posted October 21, 2012 Picture would help to solve problem. Normally the second 'axle' is used to alter the drills speed ratio one position and the handle turns whilst locating on the boss (centre) gear, And the second position locates the teeth on the outer ring of the handle's gear There should be an arrangement to allow the handle, complete with the gear wheel to be removed, and relocated onto the other axle. Pictures should clarify as this is only for one specific type of breast drill, others are available Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted October 22, 2012 Author Share Posted October 22, 2012 ok Quote Link to comment Share on other sites More sharing options...
