So I made a steak turner
So I finished my first steak turner. It's pretty simple, I drew out a long taper and bent the end, of coarse . The tricky part was consolidating the head. I attempted to weld to get rid of the grooves and failed on 2 sides. Put a twist in the handle and I'm calling it done. It's far from a master piece but I learned allot. Rome wasn't built in a day and neither are smithing skills so I will keep at it and keep the pictures coming. Any and all advise and or comments are appreciated
post-22734-0-34191900-1344731624_thumb.j
post-22734-0-47869300-1344731670_thumb.j
post-22734-0-84154200-1344732348_thumb.j
Have you tried it out? How it flips a steak is what really counts. It looks good. It can be tough putting a finial on a twist but you did well.
Thanks Frosty, haven't tried it out yet, but I will soon
Now that I've finished that, the next project is to make a grill fork. There will be a bit more planning going into this one, steak turner just kinda happened. I'm doing this cause I'll probably get to use it first, a forge cooked brat sounds wonderful. The plan is to draw out a long taper like on the steak turner but leave the end a little wide so it can be slit for the prongs. Other than that everything else will be the same. I may try something more decorative with the handle, if that works out I might change the steak turner to match. If there is any advise on how to make the fork end that would be great, other wise it looks pretty straight up. I was thinking after I slit the end to open the prongs and upset to get rid of the v although a small one won't hurt my feelings, then taper the prongs before bending them into the finished fork. I've already consolidated a rr spike back to square, this time a bit closer to success with the weld. Pictures coming soon right here.
I make forks by drawing the end out flat sort of like a longish screwdriver blade. I use a hot set to cut the tines and a veiner driven between the tines to round the fork where the tines meet.
Then I spread the tines just enough to fit over my anvil bridge. The anvil bridge is just a piece of heavy wall square tubing with a shank on one side and one side of the end ground to a rounded edge. This allows me to forge the tines without having to bend them 90* away from each other to forge.
Once the tines are finished and rounded to my taste I widen the round bottom of the tines over the horn to maybe 3/8" - 1/2" and flatten it a bit.
Oh yeah, I do the fork as the final step, the handle gets first billing and if I'm making a back pack model (I call the pig tail toasting fork) the pigs tail gets final billing.
That's it, simple in principle just takes practice and some DRATS! pile donations.
