choppertrike Posted May 19, 2012 Share Posted May 19, 2012 I wire brushed the anvil and wiped it down with WD 40, and found information stamped in the side: Wright Patent England Solid Wrought the numbers 1 1 2 (I think this is the English hundredweight designation that I've read about here, equates to 142 lbs? I'll weigh it this weekend) 1" hardy hole & appx. 5/8" pritchel hole The hardy tool is a 3/4 " Iron City item. (I'm going to tack weld a couple pieces of 1/8" stock to it to fit the hardy hole better) Thoughts & comments welcome Quote Link to comment Share on other sites More sharing options...
matto Posted May 20, 2012 Share Posted May 20, 2012 try a piece of 1" square tubing first if you have a thicker wall tubing your hardy will fit in it then the hardy with the tubing on it will fit your 1" hardy hole. saving you from tacking a piece or two on your hardy and saving your anvil wear from the weld. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 21, 2012 Share Posted May 21, 2012 I take the tubing and hacksaw it at the corners about 1/2" or more down and then fold out the tabs. Makes it sit on the anvil nicely and as mentioned serves as a wear shield as well. For my 1.5" hardy holes I've had to double sleeve but luckily I've only had to tab the outer one as the inner sq tube one is a force fit. Quote Link to comment Share on other sites More sharing options...
