Sam Salvati Posted March 26, 2012 Share Posted March 26, 2012 I have seen various incarnations of this jig but never one like this. I put it together today, some drillin and tappin and bam, Grindomatic5000. One of the best features of the KMG is the adjustable angle platen, never really though much of that til I worked up this jig. It is just a piece of HEAVY angle iron with some holes I spaced 6" apart, the bolts that go in there are adjustable stops, the blade rests on them while you grind. You center scribe your stock, the angle iron jig sits flat on the work rest, then after you figure out the proper angle for the width of stock you want to use you set the platen and just grind away to your scribe line. Works a charm! I want to do some pieces where it is ground from flat stock, then forge bent to add some curvature, it's quite a handy setup. I see using it also to rough something out then freehand it from there, nice to work off of a precise base. Quote Link to comment Share on other sites More sharing options...
MRobb Posted March 26, 2012 Share Posted March 26, 2012 Looks great. How about a video on how it works? Mitch Quote Link to comment Share on other sites More sharing options...
Sam Salvati Posted March 26, 2012 Author Share Posted March 26, 2012 Mitch, I will photo it setup on the grinder, and maybe take a short video. Quote Link to comment Share on other sites More sharing options...
Frosty Posted March 27, 2012 Share Posted March 27, 2012 That'd be good Sam, I'd like a clear view of how it works in practice. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Sam Salvati Posted March 27, 2012 Author Share Posted March 27, 2012 Here you go Frosty, the blade's spine rests on the bolts, and the tang is clamped to the angle. Here it is on the machine: Quote Link to comment Share on other sites More sharing options...
Sam Salvati Posted March 28, 2012 Author Share Posted March 28, 2012 Here I am using the Grindomatic5000 and how I grind freehand anyway, plus a dagger made using the Grindomatic5000. Quote Link to comment Share on other sites More sharing options...
