Stamped #1 steel?
what kind of steel is stamped #1 steel? I was able to pick up a piecs 8"x9" x 2.375" thick and it is stamped #1 steel. Any ideas? I can pick up a few more pieces about this size.
Sean
DME is a supplier to the injection molding business and they sell #1, #2 and #3 steel - which roughly equal 1018, 4140 and H13 (if I recall correctly). This comes in plates so that might be what you have.
Since it's not a standardized naming system *EVERY* maker and distributor can stamp whatever they like as #1 and if two are the same it's just pure blind luck.
Thomas
Ah Wooldridge san numma 1 steel is velly good steel as oppose numma 10 steel which is velly bad steel indeed
Woody,
No figga Charlie Chan is velly good bracksmith - velly good soorprize - makee rotsa dim sum.
