February 24, 201214 yr Does anyone have experience using Soybean oil for heat treating hammers and punches?
February 24, 201214 yr I use canola oil on punches and small parts. I haven't needed to heat treat a big part yet. Other people use peanut oil or other vegetable oils so I am sure that soy will work fine. Generally speaking you want a gallon of oil per pound of steel, and you want the oil warm to start with, and a lid in case of flame. Soybean oil has a higher smoke point than peanut oil. (soy 495F, peanut 437F) Phil
February 24, 201214 yr I'm pretty confident it'll work fine. If anything it may be faster than 4140 requires. However, I have no experience using soybean oil as a quenchant for anything.
February 24, 201214 yr I use peanut oil in a 7 gallon metal barrel with lid for anything needing an oil quench. Soy oil should work just fine. During the colder months, I put the barrel on top of the woodstove to heat up. On Summer's Day, no need to prewarm it.
February 29, 201214 yr I think the problem is that the soybean oil will probably become rancid over time. I like atf 4:1 with diesel to cut the flash. JE
February 29, 201214 yr From the horses mouth;http://www.crucible.com/eselector/prodbyapp/carbon/maxtool.html The soybean oil is OK, so long as the parts are not too small or complex. ATF would be a safer option if they are. Cheers, Nick
