rail spike kukri
After finishing my first rail spike knife,( http://www.iforgeiro...il-spike-knife/ ) I decided to make one for my brother.He was always a fan of the Gurkha kukri style so I decided to try that.I knew it would be tough getting the blade mass for this style,so my first attempt fullered out the tang thinking I would add a wooden handle.I scrapped that idea after too much work and decided on a twisted handle.The first attempt(after necking it smaller towards the center)broke.I had tried too tight a twist in a short area.The second try was successful,but it did develop a crack after several heats.A quick arc weld and then I finished it out.I pushed everything that was left towards the tip.It isn't exactly proportionate to the style,but it was as close as I could do with the mass. I think this is it for me and rail spike knives....although I have started a tomahawk from one. :rolleyes:
Hmm....not sure how I put the photo up last time....so here is a link:
http://s1087.photobu...lspikekukri.jpg
cool blade, would love to see how the tomahawk turns out.
I'm impressed that you were able to squeeze that much material out of a spike. Nice job. How thick is the blade?
Thanks guys.
Matt, It is right at 1/4 inch at it's thickest(at the hilt),and then tapers from there.I used my spring fuller for most of the squeezing. :)
You ought to post that over at the Kukri forum at swordforum.com. (and please remember to forget that I suggested that...)
