territorialmillworks Posted October 16, 2011 Share Posted October 16, 2011 This week I made 6 flat bit tongs on the PH. A steep learning curve with lots of failures but I finally got faster and better, enough not to be ashamed to say 'I made those myself'. So I tried to make V-bit tongs to hold square stock. The bottom tool was 1/4" thick angle welded to a plate and relieved the center of the V on the mill so not to cut thru the bit from over penetration. The top tool was made from a diagonal cut of 1" sq bar and welded a half round rod on top to help center the blow... Wasted the bir and ruined the bottom tool Hind sight, should have practiced on a short piece of stock first. LOL . What am I missing... how thick should the V-bit be? Should I hammer a piece of square bar into a large block to make the bottom tool? Do I need to make the initial bend with a sharper top tool and then use the square tool to finish the shape..Any and all ideas appreciated...THX, Keith Quote Link to comment Share on other sites More sharing options...
brianbrazealblacksmith Posted October 16, 2011 Share Posted October 16, 2011 Keith, there are many different ways to make the v-bits. I myself do them with hand tools and a hand hammer witch I do not suggest emulating. If you have the equipment, you would be better off checking out the way Grant Sarver makes his tongs, forged to finish. The only thing that I would suggest doing differently than any other tongs out there on the market is making the v-bits a little less than a 90 degree angle to hold square stock even better. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted October 16, 2011 Share Posted October 16, 2011 You must have a BIG power hammer to tear up your setup like that...a solid block works well for a bottom tool. A piece of square with one edge rounded to allow a decent hit without kicking sideways is good for a top tool. Weld a light steel rod handle at a 90 to the tool so you can see what you are doing. I never preform the bits - just put the flat over the die and swat it but a light first hit is beneficial to get the crease in the right place. Grant makes tongs all day long - maybe he'll chime in with expert advice. Quote Link to comment Share on other sites More sharing options...
Wesley Chambers Posted October 16, 2011 Share Posted October 16, 2011 I'm in the same boat with Brian, doing mine by hand but now that I have a ph I could look into crafting a jig but why not forge out to 90% on the hammer then do the V by hand, first pair I made worked for about three years and it was mild steel and the V made on the step of the anvil. Quote Link to comment Share on other sites More sharing options...
Dillon Sculpture Posted October 16, 2011 Share Posted October 16, 2011 Clifton Raph has some great powerhammer techniques on CD, might be worth a look. Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted October 16, 2011 Share Posted October 16, 2011 There are probably lots of ways to get the vee. I do mostly hand forging, and I sometimes have a striker, which helps. I've sent two views of my tooling, one old time vee swage that fits in the hardy hole and a matching vee fuller to be used in conjunction with the swage. The bolt tong in the photo has a vee bit which is 5/16" thick. I acquired the vee swage many years ago. It is forged of one piece of wrought iron, apparently hot split and opened to 90º. Some swage blocks have a vee on edge. It these tools are not in one's kit, I would arc weld up the vee swage of relatively heavy material and I would use the corner of a 3/4" to 1" square MS bar as a field expedient. Just hold and hit the bar on the diamond. Quote Link to comment Share on other sites More sharing options...
Francis Trez Cole Posted October 16, 2011 Share Posted October 16, 2011 check out these two tools for the power hammer they work real good http://www.youtube.com/watch?v=-Wq0r9KA1So http://www.youtube.com/watch?v=3_14lh_jd4s&feature=related John dose a great job as well. Grants is the man though Quote Link to comment Share on other sites More sharing options...
clinton Posted October 17, 2011 Share Posted October 17, 2011 http://www.iforgeiron.com/topic/21309-power-hammer-tong-jig-ii/page__fromsearch__1 I used this info provided by Gearhartiron it works real well for me Quote Link to comment Share on other sites More sharing options...
territorialmillworks Posted October 17, 2011 Author Share Posted October 17, 2011 Taking note of John's video I fillet welded the whole area between the base and the angle for reinforcement. I'm thinking I started out hitting too hard and the unsupported wall collapsed which caused the train wreck... Second try - perfect thanks fellows, Keith Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted October 17, 2011 Share Posted October 17, 2011 This may seem strange to some. I have taken standard jawed tongs and drilled into the end for stock holding and then drilled across the jaw about 1/2" from the end to hold rings or loops. This is drilling both jaws at once. I have also forged the (hot) jaw with piece of stock inside. Drilling works exceptionally well (AND round holed bits hold square just fine for me ). Quote Link to comment Share on other sites More sharing options...
Randy Posted October 17, 2011 Share Posted October 17, 2011 I do mine basiclly the same way that Frank does. I found a small v-block from a press brake and use that in the vise or cut of the lower web and weld on a piece to fit the hardie hole. My top tool is a hand held chisel made to a 90 degree end. As nice as it is I'd have to be making a lot of tongs to make the tooling that Gearhartiron has for it to pay for itself. I have had over a hundred tongs over the years and only found one pair that had v-grooves. All of them were made round. Didn't they have square stock or what? The v-grooves hold square and round so why weren't v's more popular? Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted October 17, 2011 Share Posted October 17, 2011 Randy, Years ago, I lucked into a set of flat and bolt tongs manufactured by ATHA. They were all size-marked. The bolt tongs bits were half round, concavo-convex. Although vee bits may be more versatile, I figured the company would sell more tongs by sizing, stamping, and making the bits half round. ¿Quien sabe? Quote Link to comment Share on other sites More sharing options...
Wesley Chambers Posted October 17, 2011 Share Posted October 17, 2011 Ten Hammers, this is a very common practice for a lot of tong jaws if Im following you in the end you have a half round cross on each bite, my buddy in school was taught this method at the Hereford school of blacksmithing. Quote Link to comment Share on other sites More sharing options...
