iGuitar93 Posted September 17, 2011 Share Posted September 17, 2011 I'm starting to learn blacksmithing and I am thinking about building a vertical railroad track anvil. It would be about 3ft tall and burried in a bucket of concrete. I was planning on welding a block of steel to the top of the rr track so I can have a larger working area. What type of steel would I need and what size should I look for? Also would I need to heat treat it. I will mainly be making knives and tomahawks. Thanks! Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 17, 2011 Share Posted September 17, 2011 If the end of the rail is larger than your hammer face, I would not add anything to it, it already is a good material to use as an anvil. I would still continue searching for a "proper" anvil and use what you have in the meantime. Phil Quote Link to comment Share on other sites More sharing options...
jeffro1205 Posted September 21, 2011 Share Posted September 21, 2011 what Phil said is right. that will be a good work surface. it may also help you with hammer control being that you have a small work area. not sure about the bucket of concrete, i have never used that as a base but wood is always good. good luck please post again and let us know how it turns out Quote Link to comment Share on other sites More sharing options...
