September 1, 201114 yr Would a electric leaf blower work as an air supply for a coal forge? Or would it be to much?
September 1, 201114 yr Way too much unless you're planning to run a cupola furnace. You'd need to choke/divert it. And personally, the noise would drive me insane.
September 1, 201114 yr I don't know what sort of motor the leaf blower uses, but I do know (from unfortunate experience) that unless it's a universal motor, it will not like being hooked up to a rheostat for long.
September 1, 201114 yr I looked around, and the blower probably does use a universal motor. So a rheostat would be a possibility. Just keep an eye on the temperature, and listen for unexplained changes in the sound it's making. Personally, I'd still be more inclined to run it at full speed and use a bleeder downwind of the blower discharge.
September 1, 201114 yr Since a blow drier will put out more air than a typical coal or charcoal forge will require a leaf blower is definite over kill and way more expensive than using something else---like a heater fan from a car for example. Putting wear on something expensive to do a job that can be done by something cheap is generally not a good idea.
September 1, 201114 yr But putting wear on something that was free is better than putting wear on something that wasn't free.
September 1, 201114 yr Would a electric leaf blower work as an air supply for a coal forge? Or would it be to much? if you look at your fire pot thread I put on a blue print for a fire pot I give information on a blower they run about $60.00 at Grainger if you are a ABANA member less. A leaf blower will work just add a damper to the in like.
