Aljeter Posted June 16, 2011 Share Posted June 16, 2011 I was thinking about building a fire pot using an old plow disk for the bottom. Then cutting a 2 1/2 to 3 inch ring off a piece of pipe that will be welded around the disk. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 16, 2011 Share Posted June 16, 2011 I've seen them done that way; you will need a taller rim to get a nice tall fire in it though. For one forge I used to use for billet welding I made a sheetmetal "fence" that dropped right inside the rim (it was a smallish brake drum) and went up higher. I made it with a couple of inches of gap where the two ends would meet so I could push my pieces in and out and also cut a mousehole opposite the gap (and above the rim) so long pieces could go all the way through. Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted June 17, 2011 Share Posted June 17, 2011 That almost describes my forge exactly and is a really common pattern in rural areas where discs are common. It would work a bit better if you cut a hole for a brake drum to deepen the fire and the rim around the edge needs to have a couple of cutouts for getting long stock down into the correct part of the fire. Quote Link to comment Share on other sites More sharing options...
Aljeter Posted June 17, 2011 Author Share Posted June 17, 2011 Thanks for the replys. Quote Link to comment Share on other sites More sharing options...
