Arbalist Posted June 8, 2011 Share Posted June 8, 2011 When folks talk about burner sizes is this the inside or outside diameter of the tube? I'm planning on making my own and have various sizes of thick walled steel tube to choose from. This site has some nice designs and I reckon I need the one inch burner but where are we measuring the "one inch"! http://www.hybridburners.com/products.html Vic. Quote Link to comment Share on other sites More sharing options...
Steve Shimanek Posted June 8, 2011 Share Posted June 8, 2011 generally pipe sizes reference the inside diameter. Quote Link to comment Share on other sites More sharing options...
sfDuck Posted June 11, 2011 Share Posted June 11, 2011 As to the thickness of the pipe,3/4 black pipe is approximatly 1/8 inch thick, and the larger the fitting the thicker the wall is. The only change would be how hot the tube gets; the thicker it is the longer it would take to heat up! As long as you keep yer tail feathers away (Don't lean on it) or cover it with a can of panty waste. Have fun. Quote Link to comment Share on other sites More sharing options...
Arbalist Posted June 11, 2011 Author Share Posted June 11, 2011 Thanks guys, I kinda thought that was the case but it doesn't hurt to make sure! Vic. Quote Link to comment Share on other sites More sharing options...
