Posted
Some where on the net I saw a hydraulic forging press that used 2 hydraulic pistons and built with an I-beam. Now that I have most of the material I can not the info anywhere. I have a 24" I-bean, hydraulic power system and the necessary hydraulic equipment. Any help would be appricated. thanks all.
  • 2 weeks later...
Posted
That's my press. It's a 60 ton two cylinder hydraulic forging press. It was made from a 24" I-beam, 23-3/4" x 7" by 56" high. Note all the extra bracing welded on the ends, top and bottom. One of the things not covered in safety on the video is to get protective sleeves for the high pressure hoses. There is also a part 2 to the video. If I can help you with anything let me know.
post-1310-0-41625800-1304043617_thumb.jp
Posted
Andrew, they are 6" cylinders, 7-1/2' square with 2-1/2" rams and the pump is a Northern Tool,16 GPM,2 stage, w/ 1/2" shaft. 2,500 PSI / MAX 3,000 PSI
Posted
Andrew, I really recommend you get "Build Your Own Hydraulic Forging Press" by Jim Batson, you can get it at the American Bladesmith site:
http://www.americanbladesmith.com/store/s-pages/ABS_Store_Forging%20Press.htm
That will give you all the specifics on cylinders, pumps, motors and set-ups.
BTW my motor is 3,450 rpm.
Stay safe!
Posted
Thank you for a reply. You have answered a few of my questions. Nice press, it is what started me on a press of my own.
