monty Posted April 11, 2011 Share Posted April 11, 2011 i have been asked to make a pair of large ring door latches (similar to ones on a church door) and need a square hole 12mm in one of the ends to attach to the bar joining the handles, does anyone have any past experiences of this? my real question is how should i go about making the hole. thanks in advance monty Quote Link to comment Share on other sites More sharing options...
clinton Posted April 11, 2011 Share Posted April 11, 2011 One way would be to drill a hole undersized then use a square drift to square it up. Do a test piece to see the result Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 11, 2011 Share Posted April 11, 2011 What about putting the sq hole in the latch ring and having the bar slide into that and get pinned? The church doors I am familiar with the rings don't twist and the actual latch is a separate item. Quote Link to comment Share on other sites More sharing options...
monty Posted April 12, 2011 Author Share Posted April 12, 2011 ok thanks i thought of the drilling, but i think that the area around the hole needs to be relatively large the bar is only 1 inch across i could upset it first though...... thanks again Quote Link to comment Share on other sites More sharing options...
