SRT02 Posted March 2, 2011 Share Posted March 2, 2011 I have been working on the handle of knife and at first I didn't want to put pins in it and just glued the pieces of the hand onto the knife with some 24 hour epoxy. After a day or two the pieces fell off. So now I've glued it up again and I'm wondering if I should try and put some pins in it. Any suggestions? Thanks a bunch. Quote Link to comment Share on other sites More sharing options...
son_of_bluegrass Posted March 2, 2011 Share Posted March 2, 2011 I would put pins in. If you don't want visible pins you may be able to do blind pins. What did you do to epoxy the handle on? If you didn't degrease / clean well enough the epoxy won't stick. If the handle material is some oily hardwood, you'll need to wipe that down to remove the oils or the epoxy won't stick. If you didn't thoroughly clean the old epoxy off, it might not stick. More details and pictures may prove useful. ron Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 3, 2011 Share Posted March 3, 2011 roughing the tang up helps too Quote Link to comment Share on other sites More sharing options...
SRT02 Posted March 3, 2011 Author Share Posted March 3, 2011 I roughed the tang up and removed the old epoxy the second time around. The wood I used is rosewood. I'll attach some pictures Quote Link to comment Share on other sites More sharing options...
rokshasa Posted March 3, 2011 Share Posted March 3, 2011 i would put some pins in that as well as apoxy just to keep it all nice and tight and fill in the gaps that may be present between the handle and the tang. if you want the pins to look better flatten the sides of your handle so that the pins can finish flush to the surface, if your hadle is rounded on the sides you'll want to get the pins that way as well and that could deform them and lead to disapointment lol trust me i know :) Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 3, 2011 Share Posted March 3, 2011 Rosewood is one of the ones that needs the surface de-oiled before epoxying to it. Wiping it with acetone is often used. (only the surface that will be epoxied!). Quote Link to comment Share on other sites More sharing options...
