monty Posted December 15, 2010 Share Posted December 15, 2010 does anyone no how to forge a cut off hardy tool? Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted December 15, 2010 Share Posted December 15, 2010 ya i have built a few ... i usually use a jack hammer bit that has broken .the bit has a shoulder built in forge so it fits hearty hole when you get close you can upset into hearty hole (keep turning 1/4 turn every few blows so it fits any direction in hole). from there forge blade part . profile on blade depends on what your cutting and how (hot or cold straight one side or even taper) i have found that if the profile is correct you dont have to harden it as usually it will get hot (for hot cut)and take the temper out anyway. on cold cut same tho its the mass that does the job . you will have to sharpen it occasionally as even if your careful you will mash the edge with the hammer (another reason not to harden). good luck! Quote Link to comment Share on other sites More sharing options...
pkrankow Posted December 15, 2010 Share Posted December 15, 2010 There are a number of different ways to do it, producing different styles of useful tools. Now I was also looking for a thread on making other hardy tools like forks, spring swages and the like, but I haven't found it. Phil Quote Link to comment Share on other sites More sharing options...
monty Posted December 19, 2010 Author Share Posted December 19, 2010 thanks guys, really helpful!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
