Timothy Miller Posted November 14, 2010 Share Posted November 14, 2010 Ever forge stuff out of these their 5160 I think and are plentiful along the tracks near my house. http://www.pandrolusa.com/eclip.shtml They leave the old ones on the ground to rust away. Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted November 14, 2010 Share Posted November 14, 2010 I have seen them before. But never made anything from them. Sounds like some good metal. Let us know how it turns out. :) Quote Link to comment Share on other sites More sharing options...
Bad Creek Blacksmith Posted November 14, 2010 Share Posted November 14, 2010 They make excellent punches, good hard steel. Quote Link to comment Share on other sites More sharing options...
Timothy Miller Posted November 14, 2010 Author Share Posted November 14, 2010 I use them all the time to make tools. They are hard. Quote Link to comment Share on other sites More sharing options...
forgemaster Posted November 15, 2010 Share Posted November 15, 2010 They hurt when you try to drive them back into a pandrol plate with a sledge hammer but don't make it and they fly out and hit you in the mouth. Good steel otherwise. Phil Quote Link to comment Share on other sites More sharing options...
Timothy Miller Posted November 15, 2010 Author Share Posted November 15, 2010 They hurt when you try to drive them back into a pandrol plate with a sledge hammer but don't make it and they fly out and hit you in the mouth. Good steel otherwise. Phil I think if I walked on the RR tracks with a sledge hammer the MTA police would have me in cuffs in short order. I would be on the news doing the perp walk wile they called me a domestic terrorist for tiring to cause a train derailment. I just pilfer the old ones it makes up for the transit tax they imposed last year in a late night unannounced vote. Quote Link to comment Share on other sites More sharing options...
forgemaster Posted November 15, 2010 Share Posted November 15, 2010 We were a few years ago making/fabricating rail turnouts for underground coal mines. We would fabricate all the rail components, switch blades, frog, check rails then assemble them on a large piece of 16mm MS plate by welding the pandrol plates down then clipping the rails etc to the plates with pandrol clips (obviously) the whole assembly was then delivered to the customer by semi trailer. They then transported the whole turnout underground and usually just dropped it into place and bolted it up. Occassionally they would also cement it in place. It was while clipping the rails into place that we found just how well a pandrol clip can fly. You really had to give the clip one good solid belt to seat it fully into the plate in one go otherwise the clips would just come out as quickly as they were driven in. We also make a handled punch for the gangs to use to drive the clips out of the sleepers, problems occur when they oxycut the clips off if they are hard to move, then try to use our punches to remove the remains still stuck in the plate. With the end of our punch being heat treated and the end of the clip now flame hardened/heat affected they have had chips fly off and hit blokes in the head and body requireing a trip to hospital and paper work to be filled out. The customer then asked us to anneal the ends of the punch to prevent this happening, problem then was that the punch would then mushroom up and then the gangs would either cut the mushrooming off with the oxy or get them stuck in the plate then cut the punch off with the oxy again. It just became a vicious circle. Phil Quote Link to comment Share on other sites More sharing options...
