Sweany Posted September 2, 2010 Share Posted September 2, 2010 I thought this was informative. about the sodium valves. scroll down about a 1/4 of the page. http://periodictable.com/Elements/011/index.html Quote Link to comment Share on other sites More sharing options...
mashin' metal Posted September 2, 2010 Share Posted September 2, 2010 neato info, thanks for sharing! Quote Link to comment Share on other sites More sharing options...
Bentiron1946 Posted September 3, 2010 Share Posted September 3, 2010 Those must be a joy to manufacture. I used some old valve stems to make my own bezel pushers for jewelry use. I made double sure from my mechanic that they were not sodium filled. That's a neat web site thanks for link, I book marked it. :) Quote Link to comment Share on other sites More sharing options...
Phil H Posted September 3, 2010 Share Posted September 3, 2010 I had an old racing motorcycle that had a sodium filled exhaust valve. I had a couple of spares, but they were as rare as hen's teeth and I certainly wouldn't have cut them up to make punches, etc. The theory was that at high temperature the sodium became liquified and circulated within the stem, thus transferring some of the heat at the head of the valve into the valve guide and into whatever medium the other end of the stem was in. In my case this was air, but more usually it was cooled by oil in the cam or rocker box. Quote Link to comment Share on other sites More sharing options...
mashin' metal Posted September 3, 2010 Share Posted September 3, 2010 I had an old racing motorcycle that had a sodium filled exhaust valve. I had a couple of spares, but they were as rare as hen's teeth and I certainly wouldn't have cut them up to make punches, etc. The theory was that at high temperature the sodium became liquified and circulated within the stem, thus transferring some of the heat at the head of the valve into the valve guide and into whatever medium the other end of the stem was in. In my case this was air, but more usually it was cooled by oil in the cam or rocker box. xxxx, have any pictures? board racer? Quote Link to comment Share on other sites More sharing options...
Bentiron1946 Posted September 3, 2010 Share Posted September 3, 2010 I didn't cut up sodium valves to make punches, that's not a good idea, just solid steel, that's OK. :blink: Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 4, 2010 Share Posted September 4, 2010 Sodium is dangerous fun stuff, we played with it some as teens. Got our refills from valves. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
