Hammer Posted August 15, 2010 Share Posted August 15, 2010 Hi all, I have a question about the Champion pump lever rivet forge. The ratchet assembly has three dogs that engage the large belt driven wheel. Is the three dogs and gear assembly suposely lubricated with oil or grease? It's making a noise when one of the dogs is draging on the gear. Any sugestions? Brian Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted August 15, 2010 Share Posted August 15, 2010 Most of this equipment needs liberal lubing so I'd say put some grease on it and see if the noise goes away. I use ATF on everything but I'm not real concerned if the excess drips a bit since my shop has a dirt floor. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted August 15, 2010 Share Posted August 15, 2010 Ratchet pawls are typically oiled as grease can interfere with their free movement. Specifically I do not know what your forge uses. Phil Quote Link to comment Share on other sites More sharing options...
Ed Steinkirchner Posted August 18, 2010 Share Posted August 18, 2010 if possable a pic would be nice, because i have rebuilt one and i have used oils pretty much exclusively. i dripped motor oil in the holes only because it stayed outside and 3 in 1 oil washed off in the rain too easily, but inside 3 in 1 would work i think. hope it helps Ed Steinkirchner Quote Link to comment Share on other sites More sharing options...
